How steam works...
vaporvac
Member Posts: 1,520
OK guys and gals, I originally posted this in response to another post, but upon further reading decided it needs its own thread. This is great stuff!!!
http://www.cincinnatitriplesteam.org/documents/SteamTables.pdf
In a recent post the value of cleaning the mud out of the boiler was questioned.... I think the answer is found here....clean that mud out! this is also another plug for wet-based boilers. There's also a great explanation on the same page 6on the value of VENTING as it relates to heat transfer and co2 corrosion....vent the heck out of those mains! And "wet" steam....again we've seen many discussions over the precise value of upping the header size, using both risers and having good separation via the equalizer... this explains very clearly why it's not wasted effort. Venting the co2 is also discussed and something we don't usually read about, but here we see why getting rid of the air is important as is reduces the co2 corrosion.
I'm sure all you smart people already knew all this, and I've gleaned quite a bit from reading this site, but this pdf just seems to put it all together in a nice tidy package with a bow on top. I wish it had all the pages mentioned.
Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF
Thanks for the heads-up. I changed it in my post.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
