Grundfos
onedriven
Member Posts: 7
Hi
Just wondering if anyone can give me some info on a circulator pump. I have a Grundfos UP 15-42 B7 circulator. Would it be okay to use it on a 5 loop system with approximately 1000 ft of pex pipe total? The system is for secondary heat only.
That should work just fine provided the boiler and other piping have average resistance."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
