PEX/manifold reccomendations
Fred Rappuhn
Member Posts: 107
I plan on re piping our hot water heat system and get rid of some ugly old baseboard fin tube and replace with panel rads. I have already done a heat loss with Slant fin's Explorer software, but looking for recommendations on which brand pex al pex and manifolds to use. Running 4 heat zones reusing existing zone valves and a home run system off from a manifold.
Panel rads and zones , interesting . How will you pipe the rads for the zoned system?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Zone valves like 3/4 sweat for example? If so a copper branch manifold from Sioux Chief or Alberta T-Drill, 1 or 1-1/4 trunk and 3/4 branches.
If you want a radiant manifold with actuators, plenty to chose from, Caleffi has a nice selection, with available PAP fittings.
http://www.caleffi.com/sites/default/files/coll_attach_file/idronics_5_0.pdfBob "hot rod" Rohr
Living the hydronic dream0 -
Using panel rad's with a zoned system is not a good idea????? My plan was to have zone valves control each manifold and home runs to each rad.0
Properly installed , a zoned panel rad provides near optimum comfort and fuel consumption . Here is additional data on manifolded systems.
http://www.caleffi.com/sites/default/files/coll_attach_file/idronics_4.pdfBob "hot rod" Rohr
Thank you for the info, I have Dan's , "Pumping Away" book and another book by Siegenthaler. I need to do some more reading, Thanks!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
