Watts boiler fill valve - not working?
28W
Member Posts: 141
in Gas Heating
Hello all. I have a 3-year-old Viessman hydronic heating system in my home. It has a Watts fill valve. Does this type of valve automatically maintain system pressure, or is it normal to have to flip the lever and raise the pressure occasionally (like once per year)?
What is the pressure reading on the gauge? Does it stay the same or is it dropping?0
It had dropped to 4 PSI over the course of a year without an adjustment. Now that I've raised the pressure, it is holding steady at 13 PSI0
It should maintain pressure (if adjusted properly). The lever you mention, is not for adjusting pressure. It is the fast-fill feature. It is for purging air from the system. It bypasses the regulator, and will allow city water pressure.The lever assembly just unscrews....notice the flats at its base. Underneath that, is the regulator adjustment. There is a screw and lock-nut underneath. Bleed some pressure off the system at a radiator. Then check the pressure.If you want to raise the pressure ,at that point, loosen the lock-nut and and turn the screw clock-wise. Monitor it for a while.0
It is not uncommon for that model to just get stuck. Sometimes just cycling the fast fill lever resolves the problem. I would keep an eye on it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks for the suggestions. So far, cycling the the fast-fill lever (now that I know what it is!) seems to have done the job.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
