1850s house - adding an addition
ruddyone
Member Posts: 1
Last year we purchased a home originally built in the 1850s in the Chicago area. It has a 4 year old boiler and old radiators throughout, which we actually love.
We are planning to expand the house soon and would love to do radiant heating in the addition. I've done a bunch of research but could really use some advice.
The planned addition basically opens up the back of the house and goes back about 40 ft. Full unfinished basement and a two story addition. (kitchen, family room and master suite)
For numerous reasons, we are trying to minimize what we do to the existing house. So, we are not planning to change out our existing boiler / radiators or spacepak.
For the addition, we were thinking to do radiant heat in the floor with hardwood. But I'm a little stuck between warmboard and thermofin. They both seem like good products. I hear that thermofin is cheaper but from what I've seen it looks like it would take more labor to install and you still have to install a sub-floor. With the warmboard, it looks like it cost more but is easier to install and you don't pay for the plywood sub-floor.
Am I thinking about this right? Is this the type of install you would recommend and if the performance is the same, for new construction which product ends up being less cost total to install?
Or, do you have something totally different you would recommend. (one contractor told us not to do radiant with wood floors and we should do baseboard heat instead)
Really happy to find this site. Thanks in advance!
First question- is your existing system steam or hot-water?All Steamed Up, Inc.
Consulting0 -
Radiant heat is not the culprit for most botched hardwood jobs . RH% is the biggest offender , Tin guys love when there is radiant installed that they can point at as opposed to their admitting they did not do their job right and the RH is allover the place .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
