Every Darn Radiator
The training has been well received and I have been fortunate enough to be able to give away some of Dan's EDR-Every Darn Radiator books. You would absolutely be stunned at how many contractors incorrectly size a boiler to a connected radiator load. This book has been a great give-away that contractors appreciate.
Dan and TLM shipped some books to WI for me and got them out the door very quickly and it was greatly appreciated.
If you don't own this book, consider purchasing it, you won't be disappointed.
Best,
Paul
Mine is getting pretty dog eared I use it that much.0
Thanks, guys! You made my day.Retired and loving it.0
Got you beat- the back cover fell off mine.Bob Bona said:Mine is getting pretty dog eared I use it that much.
Consulting1 -
It's hitting the lottery when I find the exact rad in there. The rest, close enough Thanks for the spiral binding, Dan. On my second copy of LAOSH0
Excellent idea Paul. I have been giving away copies of Pumping Away at my classes.Paul Rohrs said:I haven't been on The WALL much. I have been travelling this great country doing my best to deliver top shelf training on Basic Hydronics with a holistic approach to hydronic heating.
Best,
Paul
That PONPC is by far the hardest concept for installers and designers to grasp. I spend a few slides on it, but give away a copy of Pumping Away to the attendee with the "deer in the headlights look" when we talk PONPC.
I mistakenly gave away my autographed copy!
Is there a box quantity pricing available, Dan?
Living the hydronic dream0 -
It's amazing after all these years I still see most HW jobs piped with the pump on the return.hot rod said:
Best,
Paul
Is there a box quantity pricing available, Dan?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
I've given a few away to former employees and even plumber buddies0
Call Deb at our office, H.R. She'll make you a good deal: 800-853-8882. Thanks!hot rod said:
Best,
Paul
Is there a box quantity pricing available, Dan?Retired and loving it.0 -
Best,
Paul
Actually many of the new mod cons require pumping into the return of the boiler. That way the boiler "sees" the pump delta P. BUT, you need to move the expansion tank connection upstream of the circ.
The air eliminator should still be on the hot, supply side, just don't hang the expansion tank from it.Bob "hot rod" Rohr
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
