How Do I Remove it?
Rich Davis_2
Member Posts: 117
I need to remove the blower on a TT PS 60, how do I remove the screw that is located under the motor? All suggestions appreciated Thanks
The new motor will come with two screw drivers one phillips and and torch and that will fit down between the motor and blower.0
Thanks for the reply. I ended removing the 4 nuts that hold the burner plate and turn the plate about 80deg, then was able to get to the screws that hold the cover on the motor, removed the cover then I could reach the screw.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
