Caleffi LLH 1st timer
jonny88
jonny88 Member Posts: 1,139
edited August 2015 in THE MAIN WALL
Tight space and LLH really helped.Removed 500btuh oil boiler and oil fired water heater.Both boilers work together.Retirement home 10 beds,7 bath plus kitchen.Runs good and will do a cost comparison over the next year.
Rich_49TinmanSWEI
  • Rich_49
    Rich_49 Member Posts: 2,766
    See , how easy was that ?
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
  • jonny88
    Rich now all I need is a Pro press and really speed it up.
    Rich_49
  • NYplumber
    NYplumber Member Posts: 503
    Looks good.
    :NYplumber:
  • j a_2
    j a_2 Member Posts: 1,801
    Nice job, propress overrated, at times..,.they have there place...
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,239
    Nice work johnny. Looks clean and simple.
  • jonny88
    Thanks Harvey we used chimney as a chase for both boilers using Centrotherm.They are making a cap for both exhausts.
    hot_rod Member Posts: 22,157
    Nice installation, thanks for the Caleffi component.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,541
    Who stocks IBC?
  • j a_2
    Caleffi in my opinion is of the best products on the market....
    jonny88Rich_49kcopp
  • jonny88
    edited August 2015
    Thats the component you got to me asap so thank you@hot rod.Also got your fill valve and hi vent going to indirect.P/S no more.Caleffi mixing valve also on indirect.My supply house after constant pleading are now stocking your stuff and honestly are selling a Dirtmag with most mod/cons including Navien.
    RobG
  • RobG
    RobG Member Posts: 1,850
    Looks good Jon! What size boilers did you install? I hope you factored a new pair of Levi's into job cost. :)
  • jonny88
    They were my best jeans.Another pair gone.Two SL160 boilers,with a 80 gallon indirect.They work as master and slave with the second boiler backing up the first if and when it needs more btu's.Thanks Rob
    RobG
  • Mad Dog_2
    Mad Dog_2 Member Posts: 6,954
    Very neat and clean. Way to go jonny. Mad Dog
    RobG
