Buderus 2107 Logamatic Control wiring
paufiero
Member Posts: 1
Good Afternoon, I am an electrical installing a G115WS oil burner with the 2107 control board in Winchester Mass. I have a two part question; Do I need heat resistant wire to enter the rear of the boiler passing over the insulation to the 2107 control board or will THHN be ok. Second; Can i use the optional room sensor in place of the thermostat since there is only one Zone for the heating.
BFU sensor in lieu of thermostat? Yes,it will be constant circulation, I'd use an ECM circulator. The logamatic comes with a logabracket to provide strain relief,wire to the KO's in whatever is code in your area,we use BX.To learn more about this professional, click here to visit their ad in Find A Contractor.2
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
