Flow switches
Jack
Member Posts: 1,047
What is out there in the flow switch world that does not have a lot of pressure drop. I've only used the McDonnel Miller paddle type before and hope to find something a bit more...refined. Oh, refined and inexpensive;)
I am Not sure I've ever seen a pressure drop reading on a flow switch with a paddle.
Taco makes a flow switch with a paddle but as far as I remember they are pretty much the same device different colors and nuances to its construction is all.0 -
what type of flow rate are you needing? Is this for closed loop hydronic, or DHW application?Bob "hot rod" Rohr
Living the hydronic dream0 -
DHW. .5 gpm & up0
Is for a tankless water heater application0
Harwil built a .5 gpm for me to try, works fine right down to a small lab flow. Labeled as a Q12N C2
http://www.harwil.com/products/flow-switches/q-12nBob "hot rod" Rohr
HR...You are the man! Thanks! I think for my purposes I will use the 112 model. It has the controller mounted. The Harwil folks were very responsive and helpful.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
