How to heat in Madison WI
WisconsinHome
Member Posts: 1
Hi all,
New to all this so could use some guidance. Renovating and adding a second story to a 750 sq ft home in Madison WI.
Natural gas furnace is needs to be replaced and duct work is all messed up, so we are thinking about getting off gas altogether and changing over to a hydronic system with electric HWH as we may add PV next year.
Concerned about the cost, potential problems with leaks, and whether it will be able to get us toasty warm on the real cold days in WIsconsin winter.
Could we just do baseboard radiators on the first floor and have heat vents and cold air returns to/from each room on the 2nd floors?
Lots of other possibilities for heating the home we're looking at too but hydronic is currently the leader so wondering about best design, potential pitfalls, and better alternatives for cost of install and efficiency over time.
Thanks for any thoughts.
Sure, plenty of hydronic heat in Wisconsin. Also many savy hydronic contractors, it gets cold up there!
You will want to do a room by room heat load calculation. It may be worth spending g money to have this, and a proper design done.
You will need a heat emitter in most of the rooms, the downstairs will not heat the upstairs very well.
Plus, having some zones will give you better control of comfort and fuel costs.
Spend some time and $$ assuring the the home is well insulated and air sealed, it's the gift that keeps on giving.
Electric is an option, perhaps you have access to off peak rates, if so a buffer tank could be part of the plan.
Offsetting with PV is another good concept, there are many solar PV installations in Wisconsin.
MREA is a good source for data and ideas. Most of the members have solar and or RE homes, and years of actual first hand experience.
www.midwestrenew.orgBob "hot rod" Rohr
Living the hydronic dream0 -
Too bad you can't tap into all the hot air coming from the state capitol
(couldn't resist)All Steamed Up, Inc.
Consulting2 -
I agree. Check out his calculator from the DOEHatterasguy said:
Eliminating natural gas is not.
I would be very surprised if the price for electricity is less than 2X the cost of natural gas. If so, it would be a huge mistake on your part to switch from gas.
Provide the electric rate per KWH (using the number at the bottom of the bill and dividing by the KWH).
Provide the natural gas rate per therm (similar manner..........bottom number divided by the number of therms used).
We can tell in a minute whether it's advisable or not.
www.eia.gov/tools/faqs/heatcalc.xls"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Versahydro solar0
Follow Hot Rod's advice before doing anything; insulate and weatherseal, so you can heat your second floor with a hair dryer.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
