Amtrol Boilermate
I have an Amtrol Boilermate storage tank off a Mclane boiler. The bottom is leaking and It looks like I have to replace the gasket. Has anyone else ever had to do this? Is it as straight forward as it looks?
  • kcopp
    kcopp Member Posts: 4,432
    Depending on the age of the unit and how long it has been leaking you may be better off just going w/ a new unit.
    I have tried to do this 1 time before w/ the top down version and had poor luck w/ it sealing up.
  • billtwocase
    billtwocase Member Posts: 2,385
    Call a rep, run the serial#. Generally it is a bottle issue, and not a gasket. They have gone downhill last 15 or so years. I have a customer on his 4th within 5 years of the original instal. I have one in my own home close to 30 years old with never an issue. I have switched, I am thinking so should you
