Gas gas line install
Make sure you're not just seeing a slight drop from ambient temp changes. Watch it longer to get a baseline.0
15# ? I know some inspectors here in H that will fail you for that high. Standard is 3psi.0
Is Galvy pipe OK in your area? Your local.gas code book has all the answers....Post it and we can help him0
I thought the same thing. Galvanized wouldn't fly in my area.j a said:Is Galvy pipe OK in your area?
We have to use galv outside bbq generators etc.We do a 3# test for 30 mins.I would not be worried in your case.
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
