Plastic Pool Panel Repair/ Sealants
matt_sunwaysolar
Member Posts: 61
in Solar
Curious if anyone has any experience or recommendations on any sealants or compounds to seal/ repair plastic pool panel leaks. Manufacturers typically provide plugs for leaks that occur in the riser tubes, but I've got a project that the plugs aren't holding under the pressure and they could use a little help.
Anyone have any experience or anything they use?
Is it plastic or EPDM? If plastic,what type?matt_sunwaysolar said:Curious if anyone has any experience or recommendations on any sealants or compounds to seal/ repair plastic pool panel leaks. Manufacturers typically provide plugs for leaks that occur in the riser tubes, but I've got a project that the plugs aren't holding under the pressure and they could use a little help.
Crimp fitting?Bob "hot rod" Rohr
Living the hydronic dream0 -
Polypropylene.0
If it is under pressure, I think you will need to find a fitting to go over or into the tube.
Any ideas from the manufacturer?Bob "hot rod" Rohr
There is basically nothing that sticks to PP -- which is a huge part of what makes it such a useful material. Fusion welding and gaskets are pretty much the only ways to effect a good seal.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
