pex al pex vs weil mclain
neradiant
neradiant Member Posts: 3
I am puling a floor up for a bad radiant install and in the process have discovered they used weil mclain alumipex. They are hooked to 10 loop manifolds with actuators on them. I need to replace all the tubing in the process. Will any pex al pex tubing work?
  • Rich_49
    Rich_49 Member Posts: 2,766
    What was the initial problem that made the install bad ?
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
    hot_rod Member Posts: 22,120
    I'm pretty sure that was a Reifling brand tube. It's the same fitting that fits Watts or Uponor MultiCor, probably others as Reifling make most of the PAP out there.
    If the goal is to re-use the manifolds with new tube?
    But sometimes the o-rings on the fitting get damages. Watts used to sell spare o-rings.
    Caleffi sell manifolds with a universal PAP fittings.
  • neradiant
    This is over a slab with home made sleeper system with aluminum panels. Then they put 2" sleepers over that and the finished floor. So it was suspended down in the wood right on the slab. House does not stay up to temp when it gets below 15. New plan is to rip all wood up, insulate between old slab hook new tubing to same manifold and pour a 2" slab with tubing in the slab. The tubing would heat up in the old system just not transfer to floor.
  • Rich_49
    WOW . A suspended tube type of detail in a sleeper system . Gotta love it !
    What material will the new overpour be ? concrete , therma floor ? How many zones ?
    732-751-1560
  • neradiant
    It is 10 zones. I tried to convince them to consolidate them. But changing his mind was not happening. 20 loops total.
