Largest Gas Residential Furnace
AlPro
Member Posts: 7
in Gas Heating
Does anyone know what is the largest residential natural gas 90+ efficiency furnace available? Is there a 200,000 BTU furnace?
Thank you! :-)
Thank you! :-)
Usually 120 - 140 input is the max. Are there windows in the house?
To get 200,000 you have to twin two furnaces of 100,000 each. They have to be the exact same model and everything on them has to be set up the same. It also requires alterations to the duct work.0
Do you really need that much? We took a house with twin 100K 80% furnaces and went to a single 100K 95% and it heats fine.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
