oil tank conversion
j a_2
Member Posts: 1,801
Removing a almost new oil tank 270 gallon….anyone have a cut sheet to convert it to a nice grill…For outdoor cooking….Wanting to do that for a long time…..Now I have much more time on my hands…..I have several welding and cutting torches….Thanks
I've seen a few that had this done. The guy that took my tank claimed that's why he wanted it and then a few days later we saw it go down the road in a pickup, likely to be scrapped.
Funny thing was, I just wanted it gone. He didn't need to lie.
But yeah, if it's a newish tank and in good shape I'd say go for it. Buy a ton of lump charcoal and cook up a pig.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
For cutting, I would try to wash it out best you can and then maybe even fill it with nitrogen. I don't know how flammable diesel fumes are, but it pays to be over cautious.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
An out of business convenience store near me had an empty UG diesel tank (1000's of gallons) hit by lighting. This caused an explosion from the remaining fumes (1 year or more of being empty). Left a crater in the parking lot.
Apparently very rare happening and drew a lot of interest by investigators from afar.0 -
Oil not very flammable, same same fuel used in commercial airplanes….When I was an aircraft mech, we used to have to barrel drain fuel cells in aircraft quite often especially when we had to weigh them or go in and seal up leaks [ yup leaks] that were deferred for weeks….Some of us took it home in barrells for home heating…Oil embargo times….When atomized it becomes flammable….Any way i for sure clean it and sand blast it…Then go find a pig to roast….The southern and western quys I was stationed with in southeast asia did it all the time….Us city boys had not a clue…But loved to eat it..0
Be careful a lot of people have been killed cutting closed containers. Use a sawzall to cut it open. Don't take any chances.0
Thanks. Totally understand ...been cutting them out for lots of years....My main stay was oil to gas conversions for Boston gas keyspan and national grid....0
Follow Ed's advice. Do NOT attempt to cut it open with a torch. Fuel oil isn't all that flammable, true -- but it is somewhat, after all... that's what we use it for! A small pocket of residue or fumes left in the tank can ruin your whole day.Br. Jamie, osb
Never considered cutting it open with a torch, that would be just plain stupid…..Only said I have them available when it becomes time to start the project of making a grill out of it….After I cut it in half with sawzall….I may only be a plumber, but not that stupid lol0
I was teaching a journeyman hvac course this time last year.......and we made it our class project. 270 Gal Oil Tank, split in half and hinged.....3/4" Black Pipe and Fittings for the Handle........expanded metal grill......the right half burner was a rectangular cast iron 150M burner out of a 1962 Crane Boiler that we converted to LP..............the left half burner was one of these http://www.smokedaddyinc.com/pellet-hoppers . I wish I would have taken pictures........it was so much fun! (and yep......you could get a pig on there easy). We took a piece of 18gauge sheet metal and put a bend in it and made a heat deflector out of it. I'm gonna tackle building a smaller version for myself this spring. That one with the oil tank had 1915 sq inches of cooking surface 8-00
@ja, obviously you know what your doing, others that don't have your knowledge could read this and think cutting the tank with a torch is ok. Didn't mean to suggest U didn't know what you were doing.0
No problem. Anyway tanks are safely removed and with permit0
So, I'm going to take it that it's probably unsafe to fill it with NO2 and cut with a torch?
I figured that would be a lot safer than filled with air.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
To all. Thanks for ur concern. Yup safety is number one. I will post a picture of the pug roast....if ur in the Boston area in may. Ur all invited0
What charcoal will you be using?j a said:To all. Thanks for ur concern. Yup safety is number one. I will post a picture of the pug roast....if ur in the Boston area in may. Ur all invited
Better be careful. This is a slippery slope you're going down. C
Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Slippery as?0
Don't let the ASPCA know that you're going to roast a Pug You'll have Sarah McLachlan knocking down the door.http://en.wikipedia.org/wiki/Pugj a said:To all. Thanks for ur concern. Yup safety is number one. I will post a picture of the pug roast....if ur in the Boston area in may. Ur all invited
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
