need a furnace for my office
hot_rod
Member Posts: 22,131
I need it more for AC, but FA would be nice for shoulder season, radiant slab currently is too slow and mass (ive).
Got two Lennox options the EL296E or EL296V variable speed. With 2 stage XC16.
I'd like to add a HW coil on top for solar or wood boiler input.
Any thoughts on brand, model, and air coil options?
We installed a Rheem R96V with the EcoNet remote recently and I was impressed with the ease and installation flexibility. The R97V (full modulation) is coming soon.0
I would say if you're gonna use it just for a/c and shoulder seasons, then you probably wouldn't want the top end modulating models. Maybe a 95% with a variable speed or constant torque motor?
I've had good success with Nordyne products for over 15 years.
But, if you really wanna go all the way, their modulating 97% has been out for about 5 years and other than a limit switch, I've had no issues. I put one in my brother's house and he said the comfort level was closer to hydronic heat than forced air.
You have to use the IQ Drive control with it and shielded thermostat cable.Bob Boan
I would go with the xc17 single stage AC unit and solar ready for electric. I guess your more for water panels. Plus you need one piece of equipment that will handle the iComfort stat which is ...you heard it here first ... the best there is.0
That 96V with the Econet control is a slick setup! Be a bit before they have the matching high end A/Cs out though you can use an existing 2 stage RARL or RASL communicating A/C with an adapter that talks to the Econet system. Going with Lennox I'd sure get the variable speed and their communicating control. They have modulating furnace as well, I'd sure put the communicating control on it, otherwise I'm not impressed with how it runs on single or 2 stage stat.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
