Possibilities in disabling intermittent water test on Hydrolevel LWCO
Double D
Member Posts: 442
I know this question has been asked before but Is it possible to disable the intermittant water test on the Hydrolevel CG450 low water cutoff ?
Hatterasguy, thank you for your quick response. When you say Safgard, you mean a LWCO that does not have the intermittent self test? My next move was to do just that once I confirm the intermittent test is causing the problem. When I have a little more time I will explain why. Thanks again.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
