Trane #210 Return Trap
Vacuum_Steam
Member Posts: 2
Thanks to everyone (steamhead, JC Jones, RobG, etc.) for your prior help.
Is it still possible to buy a Trane #210 return trap? If not, is there a Hoffman or others equivalent?
This is a Burnham IN12, 2 pipe 1929 vacuum system for reference.
Thanks.
Thanks.
Barnes & Jones makes one called the Condensator:
http://barnesandjones.com/wp-content/PDFs/17 Condensator_BRT.pdf
But if the system has a Vaporstat to keep the pressure low, often it can run without using a Return Trap.All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
