Old School Cool
Pat K
Member Posts: 88
1
From http://www.kemptonsteam.org/history/the-boilers/
The boiler house originally contained 6 Babcock & Wilcox boilers providing steam at 200 lb/square inch with 150°F superheat.
The boilers were double drum water tube units, each with a total heating surface of 2690 square feet. Each had an economiser with a heating surface of 960 square feet.
The coal fired chain grate stoker of each boiler had a grate area of 72 square feet. Coal and ash handling were fully automatic.
In 1951 two additional boilers were installed next to the Babcock & Wilcox boilers. These were John Thompson water tube boilers designed to burn up to 40% low grade coal or coke breeze in “sandwich” firing with regular coal.
The total length of tubing within these boilers was approximately 1½ miles. Each boiler produced 15,000 pounds of steam per hour at a temperature of 600°F. Measured overall thermal efficiency was 84.567% during a trial lasting 14 hours in which 13,000 readings were taken.1 -
Very cool indeed! Here is another one. This is in Baltimore and if you live anywhere near Baltimore I highly recommend taking one of these cruises. They will let you into the engine room while it's running to see the triple expansion engine working. Also everything in the engine room is steam powered. It's quite a site to behold. My grandfather served in the Merchant Marines during WWII and was on these ships in the engine room. It was very special to take one of these cruises with him.
http://www.ssjohnwbrown.org/
https://www.youtube.com/watch?v=8lICFLvf5tk2 -
Oooooohhhhhhhhh. Now I really do have to visit.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
