White Powdery Substance
BillAllen
Member Posts: 103
in Oil Heating
Just installed a W/M Gold going up through a garage direct vent SS 2 feet below roof line. Noticed today in the S/P just below it some leakage for the seams of the S/P white powder little bit there. Just in a one of the joints. Boiler looks good an clean. I've seen it before on jobs but those were older boilers This is 2 months old. ??
the white powder is the residue from condensation. that powder is acidic and not a great sign of operating conditions. (unless it's sawdust) Is the boiler operating above 140 degrees within 5 min of startup? How cold is it in the garage?-1
Garage is cold just above outside temps. Actually the homeowner does create sawdust in the garage but I still think its acidic.0
Cold Start Crud in a cold chimney.
If it is a direct connect to the top of the boiler, given time, it will rot out the boiler.0 -
It would help if the boiler were in a conditioned space.0
With a cold start, not in my experience.0
Keep in mind this boiler has a tankless heater also the low limit is set higher. I'm not sure it starting from such a cold start when calling.0
The chimney is cold. Does the SS insulated chimney have the proper cleanout tee on the bottom? or is the smoke pipe just stuck in with an adapter? They "Dust" like crazy. Just not as bad as a cold start.0
Yes0
1.00
You think?0
Actually it came with a .95 W/M Gold WGTO0
Bill, is this set up as top, or rear flue? Rear flue stack temp is always lower on these, and the nozzle is good with 140 PSI. Maybe some don't know enough about nozzle size and pressure rating0
Top flue goes straight up 10 feet to roof. 7". SS 3 feet below roof line. Boiler working great looks great but I notice a little acid going on at one joint about 6 feet up. This boiler is in a garage the garage is not heated but is insulated and sheetrocked.0
How is the shanty cap? Does it have a tee?0
The cap can be removed for cleaning at the roof top. No tee.0
Barometric draft0
Possibly I could have come off the top of the boiler with a 7" 90
then a 7" T and pipe it up from there. This still does not answer the acidic problem higher.0 -
Not if it's a 4 section Ice
Total mistake .not an atmospheric.
i apologize. . still as you can take it off the back of the boiler that would be the better choice.0 -
Don't do that. WTGO's that come off the top are noisy and a PITA to clean because you have to remove the smoke pipe to clean them.BillAllen said:Possibly I could have come off the top of the boiler with a 7" 90
WTGO's that come with .95 GPH nozzles are 3 section boilers, If you get the special energy ones, they go down to .65 GPH.billtwocase said:Not if it's a 4 section Ice
WTGO's come standard with 1.20 GPH nozzles. If you get the down rated ones, they came with 1.00 GPH nozzles.
You can fire a WTGO boiler at 1.oo GPH and the numbers aren't bad. They are just better with a .85 GPH at 140# Pressure.
At least the ones I installed did, and my own personal one did.
You can drop the pump pressure to 100# and use the 1.00 GPH, but the numbers won't be as good. Especially on a cold start when it is cold.
IME
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
