Burnham Domestic water coil gasket replacement
rickwilt
Member Posts: 1
in Oil Heating
I am pretty handy and would like to tackle the replacement of the heater cover plate gasket
I assume you have to drain the boiler, if this is correct I will have to drain the whole system as the valves are old and I know will leak
Thanks for any reply
If it was an RS series, I say go for it. If it is a "V" series, wait for warm weather, and hire someone to do it0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
