Spring Coupler
BillEllen
Member Posts: 2
in Gas Heating
Bell & Gossett sells 2 motor/pump couplers for the series 100 heating system motor. Either one may be used. My original is stamped steel and that replacement seems to cost more than the cast iron.
1 - Bell & Gossett 189110 Spring Coupler (stamped steel)
2 - Bell & Gossett 118705 Spring Coupler (cast iron)
I sent an email to B&G asking which one is best to use and why but received no reply.
Which one would a heating system professional choose.
Bill
Bill
B&G has plastic ones, Those were really fine unless you has issues or a larger than normal motor.
P-3 pumps take a cast iron coupler that is slightly larger and heavier than standard. The only way you could tell the difference was if you had them side by side.
The part about what is in the truck at the time is true. My supplier only supplied aftermarket couplers. I only bought the heavier kind. The difference in price wasn't worth having to go back for a free service call.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
