Have a Warren Webster Hot Water Heater Model 12H21 (old); Want to hook up in garage.
what kind of thermostat do I need to make it operate the circulator on my oil/hot water furnace.
Warren Webster heater has 6 wires-green/white/yellow/red/black/blue.
Please advise. Thanks.
  • salvetmike
    salvetmike Member Posts: 8
    can anyone help with my problem?
  • Abracadabra
    Abracadabra Member Posts: 1,948
    Your question leaves some things to the imagination. A water circ only needs 2 wires. Not sure why you are bringing up the wires on the boiler. Are you looking for a room thermostat or an aquastat?
  • salvetmike
    well to tell the truth, I don't know what I'm doing! Found your site and I'm trying to figure out how to hook this thing up to run off my oil furnace. There is so little info on the heater that I don't know what to do. I can't tell you the difference between a aquastat or room thermostat. All I know is the fan motor has all these wires coming off it and I don't have a clue as to how to hook it up and to what. I appreciate the help.
    Steamhead Member Posts: 16,835
    Take a picture and post it here.
    Consulting
  • salvetmike
    these are the pics of heater. thanks for the help.
  • salvetmike
    The info on the motor is Packard Inc. stock no 81617, mod# 8214365039. made in mexico... Thermally protected class b conduit. Air over hp115, rpm1550, v115/208-230, hz 60, amps 2.1/1.1, and this # was down by the trade mark, v111.03. Hope this helps you. Thanks for the time.
  • salvetmike
    I also need to know what type of thermostat to use with this heater.
  • salvetmike
    Thank you Don! But I have one more question??? Will the Circulator on the furnace run off the thermostat and is it wired into the thermostat?
  • Don_197
    Don_197 Member Posts: 184
    Sorry it took so long to respond Mike. You have now given more information that may mean the info I provided you is not correct. If that is a multi voltage motor, it MAY be wired for 208 vs 115.............you will need to verify this.........with the wiring diagram on the motor. I think you are now out of your realm.........you need a pro to help you with this. the circulator can either operate with an isolation relay off the line voltage thermostat that you would use to turn the fan on or off with a heat call, or you could wire it to run continuously (not a bad idea on shop heater). Call a pro to help you.
  • salvetmike
    Thanks Don, I really appreciate your help! You did lead me in the right direction from the start. I now know that I need a pro.
    Much thanks, Mike.
