How do I clean out a clogged radiator?
vintagewoodwork
Member Posts: 1
Two pipe steam system, salvaged radiator, only heats half way across.
I've been hands on in the heating business for 30 years and have never seen a radiator heat partially due to clogging.
Something else is wrong. Hire someone who knows what they're looking at.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
Steam running through pipes is pretty clean, so John is right-something else is going on. Is this a replacement radiator, or a new addition?
Check the size of the radiator, compared to the pipe feeding it.
Is there any water-hammer, indicating a water-pocket, restricting the flow? Could the steam be therefore arriving later than the other rads, so it does not get the full cycle time of steam? Is your thermostat set right for steam? Is there a crossover trap not letting the air out of that line quickly enough? Getting some of the steam books from the shop here will point you in the right direction.--NBC1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
