Water Test
Hilly
Member Posts: 427
I got an e-mail from a friend with this water analysis. He does have potable water coming from this well and make-up water for his heating system. Can anyone recommend what he'll need to clean up his water or point me (doing a bit of leg work for him) in the right direction, whether it's to a website, company, sales rep.... I'm just trying to get him on the right track before he starts living in this home. Thanks for any advice and/or direction. There's a link to the actual report he received.
https://www.dropbox.com/sh/wv9tic9u85skv6h/AAAybeXTemMEF-WBrDFpk6wRa?dl=0
Its my understanding of water treatment that the water isn't too bad. It has a high PH and high Magnesium which contributes to the hardness. It also is very high in iron. Iron is a form of hardness and some can be removed with a water softener. The softener will work better with the higher PH. The chlorides are high. Are you near the ocean or a big highway that gets ice removal with a lot of salt?
Water treatment is really a very specialized field. The person is going to need some filtration. Especially over the iron. And a professional water treatment company with a good reputation for installs in your area is really a good place to start.
Iron is the tough one. If you use a Softener, you need to use a lot of Iron Out in the brine tank to keep the Cation/Resin bed clean. With water like that, there must be others around that have systems. What do they use? Be sure that they install a filter that backwashes/regenerates with a METER and not just on a calendar basis. It can waste precious treated water or give you untreated water while waiting for a backwash cycle.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
