Homart damper control
RLS
Member Posts: 4
Homart damper control for wood fired boiler is missing thermostat that came with it. What three wire thermostat, either Homart if one could be found or comparable one if it can't, could be used with existing homart damper control?
Existing damper control unit works manually but need thermostat for automatic operation.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
