Help finding a fitting
SWEI
SWEI Posts: 7,342
I'm striking out at the supply houses trying to find what seems like a simple thing: A concentric copper or brass reducer with a 3/4" sweat internal size and an NPT (whatever size) male outside. Kind of like a T x S PVC bushing, but in copper or brass.
Anyone know who might make these?
thanks~
  • DanHolohan
    DanHolohan Posts: 16,737
    Do you mean like this?
    Retired and loving it.
  • SWEI
    SWEI Posts: 7,342
    That looks like a standard 3/4" MA.
    Turns out Brasscraft makes what I'm looking for.
    http://www.brasscraft.com/PDF/300.230_PSA_Series_MIP_x_Sweat_Adaptor.pdf
  • DanHolohan
    Ah, what are you up to?
    hot_rod Posts: 28,865
    Called a uriinal adapter around here
    icesailor
  • SWEI
    SWEI Posts: 7,342
    edited October 2014
    Installing a Pasco 1450W thermowell into an IPT tee. Nobody makes thermowells with probe lengths under one inch, plus they are all set up for 1/4" OD thermistors.
    Pasco uses them for dial thermometers. We use them for pipes under 1-1/4", and they also happen to fit the oddball 3/8" OD 12k thermistors that some of the boiler manufacturers supply. Nobody stocks 12k thermistors with 1/4" bodies.
  • DanHolohan
    If I'm ever on Gilligan's Island. I'd like you and a Swiss Army knife to be there as well.
    JohnNYCanucker
  • markp1
    markp1 Posts: 56
    http://www.supplyhouse.com/Cello-WP4-2-12-3-4-FTG-x-Male-Street-Adapter-1044000-p
    I think that is what you are looking for? Street 3/4 to 3/4 male NPT?
  • icesailor
    icesailor Posts: 7,260
    Every Sloan copper kit has one in it.
  • SWEI
    SWEI Posts: 7,342
    edited October 2014
    Ordered a dozen of the Brasscraft PSA-12's from Ferguson (who had them in the TX DC.
    Good to know on the urinal adapter if I get in a pinch again. Looks like it might be p/n 3308607 on this?
  • icesailor
    Sloan Urinal Adapter kits cost a lot more money as the kit than the single fitting alone. At $60.00 per hour equals $1.00 per minute, its usually more cost effective to buy the whole kit to get the fitting than to go on a parts safari to the parts supply houses and find that they don't have what you want.
    Those round trips to the supply house can really hurt the bottom profit line.
