Are all threaded fittings the same?
ChrisJ
Member Posts: 15,709
When dealing with iron threaded fittings are they generally all the same dimensions from different manufacturers? And what about older ones?
For example if I take a new Ward 2" ell should it match an older one on a steam system or are there often differences?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
Chris are you talking about center to end dimensions or the thread dimensions? The center to end dimension from the center of one pipe to the entrance of the other pipe? So if you take out one 2" ell will a new ell be a direct replacement. In my experience with fitting of all kinds there are definite variations, but they shouldn't be such that you can't swap one for another. Some of the really old stuff might be out of current standards, but standards probably didn't exist when they were made. Of course I have also seen manufacturers having one set of dims in their catalog, a different set of dims on the 3D model from their website and the real world part not matching either one of those. So sometimes it feels like a game of darts.1
KC,
Yeah that's basically what I'm asking. Right now it applies to the 1 1/4" 45 and 90 I'm about to bust out on that short runout.
Then it occurred to me what about if you replace something like a tee on a steam main assuming you've got a union close by or something. Will a modern tee drop right in, or would it end up a hair too wide or short etc.
Up until now I automatically assumed all of them were slightly different aside from the angle and NPT part then I started thinking perhaps there are standard dimensions.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
