Hello Gentlemen Im trying to split my one zone hydronic system into 3 zones.2nd floor consists of 3
jerseyfitter
Member Posts: 11
in Gas Heating
pieces of CI baseboard.These are piped to basement individually ,3 3/4 supplies and 3 returns.What type of system would you suggest? 1pipe,2 pipe reverse return ect. The other zones are series loops.
Sounds like its a mono flow system. Be careful here they can be a nightmare if not piped correct. Also how much radiation per zone? Micro zoning can be a problem and cause the boiler to short cycle. Don't use wild temp differences between the zones.
I would pipe the 2nd fl to a manifold set up Keeps it simple and balances the flow to each radiator.
I would certainly use zone valves vs. circulators.
What are you using for a boiler?5 -
older slantfin 90 hw boiler0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
