To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Electro Zone valve control issues
DCValveDCValve Member Posts: 1
I am in a bit of a bind. I am working on a 3 zone system that has 20 Volt DC, NOT AC, valve controls.  They are called Electro Zone and apparently went out of business in the early 70s. I cant find any info on them and hoping someone here may be able to lend some assistance.
Three coils and they all OHM fine. Coil issue can be ruled out. With one zone on, I read 19.4 volts, with two or three on, I read 18.1 volts. I wonder if this is enough to open the valves or not.  I am really not sure where to go from here or how to troubleshoot these valves. Any advice is appreciated.  Thanks.
  • icesailoricesailor Member Posts: 7,265
    DC Zone Valve coils:
    Are you sure that the coils are DC? Does it have a rectifier to convert the AC to DC?
    Are they wax motor expansion valves or are they rotor motors that rotate a valve open?
    Can you take photos of the valves? Do you know what an "Amp Mate" is that measures the amperage through the valve from the thermostat, through the valve and through the coils?
    edited August 2014
    Electrozone valves:
    There was a discussion here in 2005 about them.
    Here is another one in 2011 about them.
    It seems that the best thing to do is replace them. It shouldn't be a biggy. The newer Taco zone valves work well. I always used wax motor 572's but I was happy with the last ESP Taco valves.
    https://groups.google.com/forum/#!topic/alt.home.repair/lQLcSJgxRGQ
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
