Direct Venting Slant/Fin Intrepid TR-30 HPT
Im having a wood gassifiier installed and won't be able to use the chimney. I know when I purchased this unit it was an atmospheric unit as well. I know many don't like DV but the oil will rarely come on. Will this unit require anything special besides a DV kit?
I also wanted to know the best way to isolate each of my 5 zones in order to change my current baseboard to low temp baseboard without interrupting the rest of the system.
  • kcopp
    kcopp Member Posts: 4,431
    Direct venting....
    an Oil boiler is not something you add to a set up...it is a package you buy. Since you had an natural draft set up that is all you can do. It has to come from the factory set up and certified to do that.
    Now you may be able to by a power venter by Field or Tjernlund....
