Cast Iron chambers needed
old_dog
Member Posts: 2
Does anyone know where I could find American Standard Cast iron chambers
(need 3)
boiler number PFA-313 Series 1B-J1
This is a 40 year old unit.
Claude
(need 3)
Claude
Sure about that model number?
This would have been an A-3 series set up for pressure-firing, but the way the model numbers worked on this series, you're describing a 13-section boiler. Do you know how many sections it has?All Steamed Up, Inc.
Consulting0 -
# of chambers
I think there are now 7, but some were removed.
Don't know what it had originally.
3 are now shot. Trying to milk a couple
more years out of it as we insulate and
change windows to this converted school.
Then will put in a new unit at around 1/2 the
capacity.
I will try to get a couple pics posted Monday,
and verify the Model/Series number.
Thanks for the help.
Claude0 -
Old boiler repair
It would be best to bite the bullet, and replace it with a new wet base boiler, and a burner which can be fired within the ranges of the present radiation, and any future additions you may make.
Is this a 1-pipe, or 2-pipe system?
When you dismantle a 40-year old boiler, there can be unpleasant surprises. Finding new press nipples to rejoin the new sections (if even they can be found), could be difficult.
A 7 section boiler is in the range of 1,000,000 to 1,300,000 btu, and could be replaced by a pair of smaller pre-assembled boilers, staged by pressure.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
