To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Vitodens 100-W Cycles But Won't Ingite, No Error Message
Jake48Jake48 Member Posts: 28
My 2007 Viessmann Vitodens 100-W30 cycles continuously but won't ignite. There is no error message. This is the first time I have had a problem with this unit in which there was no Fault Code (error message).
In past I had stuck flapper in 2010 but got F-5 fault.
In 2011 I had low pressure from bad feed reg valve but got Low pressure fault.
The pressure is fine this time.
Is it a stuck flapper again? Is so, why no error message?
Anyone know what might be wrong?
  • ChrisChris Member Posts: 3,040
    Flow Switch
    Generally you would not see an error code if you're not making the flow switch or the boiler is air bound.
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
  • Jake48Jake48 Member Posts: 28
    Flow Switch
    Can you elaborate, I don't know what you mean?
    I just got off the phone with Viessmann tech service and they think it is the gas valve.
    There's A
    Flow switch in the boiler. If you don't make the flow switch the boiler will just sit there and do what it's doing. No flow no go. That would be the 1st thing I check. Here's the service and install manual..
    http://www.viessmann-us.com/content/dam/internet-ca/pdfs/doc/wb1/vitodens_100_is.pdf
    No Flow Switch
    There is no part in the manual called "flow switch"
    New Clue
    Ok Chris found the pressure switch and when I cycled on felt water flowing through so not that. However, I realized when it cycles, it is actually heating up raising the unit temp from 75 to 82 then shuts off. So that means it is actually firing and lighting, correct?
    So why does it keep shutting down?
    edited July 2014
    Suggest
    You call a professional. Didn't say pressure switch, said flow switch
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
