To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
What's your favorite jacketed electric water for use as a storage tank?
BigRobBigRob Member Posts: 215
What's your favorite jacketed electric water for use as a storage tank? Is there a value leader in the 40 gallon range? I've heard of people removing the heating elements and piping the supply and return there.
What are your thoughts?
  • icesailoricesailor Member Posts: 7,265
    Value:
    There are only a few water heater tank manufacturers. They are very competitively priced. I personally think that a 50 gallon tank is the best bang for the money spent.
    If you are going to use it as a "side-arm" heater/storage tank, you do not need to remove any elements. However, if you insist, remove the bottom element and send the hot into there. There is no advantage to removing both elements. I've never removed ANY elements in years of using tanks.
  • BigRobBigRob Member Posts: 215
    Tank linings
    Thanks for the tips. Any tank linings to be mindful of for use in a closed system?
    Location, Location, Location:
    Don't install the tank in a location (like behind a boiler) where it becomes a PITA to remove the tank.
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
