To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Second guessing
Looked at a radiant slab install for a customer last week. The customer had radiant installed in another building using a different contractor. ( I spent two days redoing that so it was done properly) I had my wholesaler do a heat loss for the new building slab and it just seems off. Might be I have not done a floor in a long time.
40x40 building with a first floor that is 2x6 construction. The slab is basically the basement with the foundation being half above grade and half below. There are two 12x13 roll up doors and a steel entry door. The 8' foundation walls that are below grade are not insulated. 4' slab, 13'6" height to heated first floor ceiling.
Wholesaler came up with 12 loops of 1/2" tubing @ 200' loop lengths.
Designed for 115 water temp at 0 degree design temp.
Maybe I am just off but it seems like a lot of tubing?
  • ZmanZman Member Posts: 3,196
    Questions
    Are you saying you are heating a 1600 sq foot space with tubing at 9" centers or are there 2 floors?
    What kind of underslab insulation?
    Albert Einstein
  • AFOCTAFOCT Member Posts: 3
    Answers
    The building is basically a one floor house. I am just putting the tubing in the floor of the basement. Unfortunately he purchased enough "insulation to do this floor from the previous contractor. It is insultarp. ( Don't get me started on this stuff) I did talk him into 2" perimeter insulation.
    Output
    Siggy's software puts your output at about 62K BTU or 39BTU/ft. at the 115 design temp.
    That seems a little high but considering the insutarp (I agree it is crap) and the under insulated walls I think I would run with it unless you do a heat loss calc that tells you different.
    Too much radiation is never a bad thing, particularly if you are running a condensing boiler.
    Albert Einstein
  • SWEISWEI Member Posts: 7,356
    Not quite clear
    Are you planning to heat the basement and let the first floor (which sounds like it could be 4 feet above ground level) live with the leftovers?
    Yeah the second floor will be heated off a second zone. My heat loss came up with 63k. I think I just haven't done a radiant install in awhile so I must just be overthinking it. The boiler is gonna be condenser.
    Thanks for the input fellas!!!
  • RichRich Member Posts: 2,130
    12 @ 200
    Is 12" oc layout . 1,600 ft building , 2400 feet of tube .  Besides the lack of quality insulation . Sounds as if the average depth below grade is 4' , any chance the guy will excavate tat and install 2 - 4" of EPS or XPS up against that wall ? That would be a huge help .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
    12"?
    Rich,
    Wouldn't 12" centers be about 1,600 feet of tubing? It would be a little more for the manifolds but pretty close to a tube every foot. Certainly not 2,400 feet of tube in the floor.
    Carl
    Albert Einstein
    Z
     there are in fact 3 lineal feet of tubing in two square feet . @ 0" - 12" - 24" .  And due to the time of my post last night I reverted to my default 1 trip to the supply house calculation , I do apologise , after reading this now in my office after coffee and being wide awake I correct myself and say 12" center would require along the lines of  1,850 ft with leader lengths and 9" spacing would require about 2340 feet . You are correct .
    No worries...
    I was checking my own sanity more than anything.....
    Albert Einstein
    Default in my mind
    when I am out in a remote site I always order 3 lineal feet for every 2 square , 0" 12" 24" , 3 lineal feet for 2 sq . We save lots of trips this way and always have stuff in shop for those small jobs .
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
