Goodman blower motor won't start.
nukmonkey
Member Posts: 1
There is no air coming from the ducts in my house. The outdoor heat pump unit seems to be running correctly. I turned the heatpump off and put the fan in "on" and scrambled into the crawlspace to check it out. From what I can see the blower tries to start, spins for maybe a second, then stops. This cycle continually repeats. I can't see anything obviously wrong, the unit can't be more than two or three years old. The model number for the air handler is avptc313714aa. I have a newborn and really need this thing to blow cold again. I should still have parts warranty, and I reckon it's the blower motor that has gone but want another opinion before I start replacing parts on an almost new system.
IFM
Your air handler has a variable speed motor controlled by a system of electronic "languages" involving the thermostat and the controls in the air handler. Your parts are under a 10-year warranty. In your best interests, call your installer for diagnosis and solution.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
