Wood with mod/con. Piping help please
Chrissalva
Member Posts: 1
Hey guys,
I'm putting in a Harman SF260 with a mod/com backup. The system is mostly cast iron radiators with thermostatic heads on them. I also have an indirect DHW tank. What do all recommend for a piping method? Primary/secondary? The manual doesn't show a tie-in with a mod/con. Is there any diagrams out there? I was also told I should put a mixing valve in to prevent the water temp getting too high and short cycling the thermostatic heads. Any thoughts/experience with that? Any help would be awesome. Thank you.
Chris
Chris
Piping
Here is a good read on the subject.
http://www.caleffi.com/sites/default/files/coll_attach_file/idronics_10.pdf
The points I would be most aware of is the need for a buffer tank and if the boiler is going to be in the house, a good thermal bypass loop.
You cannot just shut off a wood boiler the potential for overheating is huge.
The expansion tank location in the manual is incorrect.
Albert Einstein0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
