boiler venting
hi
Member Posts: 31
I have a Burnham IN7 gas boiler and i would like do build an enclosure around it and would like to make a duct to outside to give it fresh air for combustion what size duct would i need??
Contact
The manufacture0 -
combustion air
Please do yourself a huge favor….Contact someone lic. in the field...0 -
Preventing cold air from coming into the boiler during the off periods
Give some thought to protecting the boiler from freezing, while there is no call for heat.--NBC0 -
fan in a can
look up field controls and size the right size fan for your boiler.when your boiler comes on have the fan wired to come on with boiler either that or make some pretty big holes in your wall0 -
passive makeup air
Passive MUA does not work reliably and under certain conditions may hurt0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
