To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Whole house de-humidifier
SnowmeltSnowmelt Member Posts: 746
I'm doing some a/c coil cleaning at a church which went well ( 1 rooftop unit, 1 traditional condenser on roof, 2 ductless units on ground.) in basement they had an old condenser unit. Inside by a window that was missing, 3 feet from that was a set of mechanical louvers that are suppose to open. Which they barley do, I think the motor is shot. Any ways now they want to put a de-humidifier in basement.
Any suggestions, I'm a Honeywell guy , any suggestion on the true dry DR 120,90 or 65 systems. Would I want to duct it out so I get the basement. Depending on size of basement should I just get the larger one & maybe but a vent in hall way, the person in charge may want one for upstairs also.
Once again any suggestions?
  • RichRich Member Posts: 2,129
    Look at
    Ultra Aire SD12 .  180 pints a day and 4300 BTU sensible cooling if needed
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
  • SnowmeltSnowmelt Member Posts: 746
    edited June 2014
    Thanks rich, what supply house has it.
    GPS,
    Johnstone ?
    For right now it's a basement one side is 600 sq. other side of basement is 800 sq ft.
    While we're on the subject. Can you give me a quick explanation how radiant cooling works. Or should I say what materials.
  • heatpro02920heatpro02920 Member Posts: 991
    In my area
    I usually try to install central as with an air exchanger vs a dehumidifier, some places have more humidity issues and need a designated unit, but in most cases the ac works well...
    I am installing 2 ultra aire units in a 2400 sq ft 2 story home in a couple weeks, their home will not stay comfortable with just central a/c, they need to set the temp way to cold to keep the humidity down on days where the dew point is any where near the air temp... But the house has some issues, running water under a crawl space {half slab on grade half 3' ft dirt crawl}..
    Anyway, I use honey well, april aire, ultra aire, ect, they are all decent, you do get what you pay for, but they are now all pretty close in price, like always the install is going to be the make or break issue- size it correctly, install it by the book, insulate well, and set the controls up correctly....
  • SpenceSpence Member Posts: 316
    Church
    Don't forget about ERVs.
  • TonySTonyS Member Posts: 849
    Daikin Quaternity
    ductless hp with internal solenoids allows indoor coil to be partially used as condenser effectively allowing for dehumidification without temperature change. very quiet.
    I have also been using the White Rodgers stat with dehumidification control. This is just a relay in the stat that is unenergized until humidity level is reached and then energized. All my ecm units have the de terminal ready to go but if using on an older system a rib relay can be easily used to change motor speeds to slow airspeed over the coil until humidity level reached. I find bringing airflow back to 75% really gives a (properly sized unit) time to clean out the humidity.
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
