To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Whoops!
That insulation that comes with the TXV is for the foolhardy said the knuckleheaded airhead as he pitched it in the trash along with the service manuals. I don't know why manufactures have to be so wasteful all the time? Just more trash I have to clean up, he mutters under his breath.
Harvey
Ramer Mechanical
ramermechanical.com
  • TechmanTechman Member Posts: 2,143
    Whoops
    I save those TXV insulation covers and sell it to someone who really needs one. LOL . A fine point here, the TXV thermal bulb is upside down , the same applies to temp control sensing bulbs.
  • Harvey RamerHarvey Ramer Member Posts: 1,744
    Flip Flop
    The air handler is actually horizontal, Terry. These computers think they know best and this one wasn't having a horizontal airhandler. It prefers vertical.
    Harvey
    Ramer Mechanical
    ramermechanical.com
  • meplumbermeplumber Member Posts: 678
    TXV
    Harvey, that poor TXV is probably hunting all over the map.  Don't you hate that?
  • NYplumberNYplumber Member Posts: 472
    Manuals
    Manuals are just so when you kneel down you dont dirty the your clean pants. :)
    Probably a novice question, however why dont they come strapped and insulated from the manufacture?
    :NYplumber:
  • icesailoricesailor Member Posts: 7,265
    Manuals:
    I thought the pages in the manuals were for ripping out, soaking in paint thinner, and lighting them afire. Then throwing them into the combustion chamber to light the fuel when it won't auto light. Emergency igniters.
  • SpenceSpence Member Posts: 316
    Insulation
    The manufacturer may not insulate the feeler bulb at the evaporator exit because the ambient surroundings will not have an effect on the target superheat. If the bulb is mounted outside the coil enclosure then insulation is critical.
    I am not familiar with manufacturers who do not mount the bulb. If you need to do this, make sure it is in either the ten o'clock or the two o'clock position on the vapor line.
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
