To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
BTU's Needed?
DonKDonK Member Posts: 1
Great site.
I am converting to gas heat from oil. Two story stone house, outside Philadelphia PA, is 85 years old, 1,600 square feet.
Two estimates s far, both through the flu venting. One is for a 96,000 BTU Burnham gas boiler. The second is for 132,000 Buderus boiler.
Why the large disparity in recommended BTUs?
Thanks in advance for your help.
  • Jean-David BeyerJean-David Beyer Member Posts: 2,510
    Because at most one of those contractors did a heat loss calculation?
  • Jean-David is right.
    But it's not unusual for bids to come in without heatloss calculations. The questions is, who do you choose to do the work.
    If I were you, I would call a reliable contractor and pay to have him do the heatloss calculations for your home. If you click on "Find a Contractor" above, there seems to be many in your area and I recognize a few of them who are quite active and knowledgeable here on The Wall. With these calculations in hand, you can give copies of them to other contractors that you ask to bid on your boiler replacement. That way, everyone is bidding on at least the same calc's.
    The contractor that does the calc's. may even give you a bid and offer to credit back the charge for the calc's. if he does the work.
    Often wrong, never in doubt.
  • icesailoricesailor Member Posts: 7,265
    A lot of guys:
    A lot of guys (or a few) would have done a complete heat loss for the building. Which means room by room. Measured installed radiation and done a comparison to what is there as to what is needed. Compared it to the boiler that is there, and on the quote, made some measure of letting you know that the calculations were done, and because it was done, your boiler was either OK or XX oversized so you could use a smaller or less expensive boiler and any other important things you can suggest.
    Some are only interested in price. The rest are  interested in price and quality. But I would never give my worksheets to a potential customer. Maybe once I have the job or started, but never so they could pass it around for others to say "No matter what the price is, I'll do it for $100.00 below that".
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
