Oil to gas conversion "direct vent"
Jlamb
Member Posts: 14
in Gas Heating
Can anyone tell me if there would be an issue converting a pensotti direct vent oil boiler about 2 years old to natural gas?
I dont think....
The Is there a direct vent gas fired conversion burner? Not sure there is one....0 -
Liability
Unless there is a kit from Pensotti that is certified for the boiler, you will have a liability issue. If we replace a burner on a boiler here, we are required to get the boiler re-certified.0 -
That Pensotti
probably has a Riello burner on it. I'd check with Riello- they now market a gas conversion burner.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
