To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Triangle Tube Prestige Solo
JonnyAJonnyA Member Posts: 1
A Triangle Tube Prestige Solo 175 was recommended. Can anyone tell me how reliable this unit is? Was also considering Weil-Mclain or a Buderus. I am looking for a high efficiency reliable gas boiler.
  • JStarJStar Member Posts: 2,668
    Triangle Tube
    It's the only brand we use right now. Huge thumbs up!
    - Joe Starosielec
    [email protected]
  • ZmanZman Member Posts: 3,175
    Solo
    Great boiler, excellent support.
    Be sure to get an installer that understands Mod/con boilers.
    A 175 is a larger boiler. How was the sizing determined?
    Carl
    Albert Einstein
  • heatpro02920heatpro02920 Member Posts: 991
    I use a solo 175 in my own house
    Its is a large boiler, oversized for my 4000 sq ft.. Make sure you perform a heatloss and install what you need, larger will cause problems..
  • Bob BonaBob Bona Member Posts: 1,992
    have a 110
    In my own house. It is THE boiler to have all things considered IMO. be sure a structure heat loss is done and the installer follows the installation instructions to the letter.
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
