Floor Support?
VelvetFoot
Member Posts: 48
I'm going to be routing some 1.5" copper pipe in my basement and I'll need a floor support or two. I was thinking wood. Would there be a pro way to do this. Don't want to make it look like a total cob job. Partial, sure.
Thanks.
Thanks.
Unistrut
I usually make an "I" out of unistrut. You can weld it together or use angle brackets and bolts. if you do this then you can anchor the bottom using screws and washers or concrete anchors (depending on the floor) and use a unistrut clamp to clamp the pipe to the unistrut on top. You end up with a very good solid support that will not rot or move. I have seen to many wooden supports that are rotted to want to ever put on in myself.0 -
Thanks!
Much!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
