Can a Circulator Pump Past a Stopped Downstream Pump?
VelvetFoot
VelvetFoot Member Posts: 48
I'm thinking about a piping schematic. I was wondering if a boiler circulator pump can pump past a downstream zone circulator that is stopped. I'm hoping it can't. Thanks.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,322
    why would it not be able to?
    yes it can. unless the head for that zone exceeds the pump curve.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • VelvetFoot
    I thought maybe the motor
    might be involved. Thanks for clearing it up for me.
  • Ironman
    Ironman Member Posts: 7,376
    Motor
    The impeller in the down stream circ will cause some resistance to flow, but like Charlie said, it won't stop it.
    Bob Boan
    hot_rod Member Posts: 22,139
    that's common in solar drainbacks
    two circs run to fill and establish the siphon, then the downstream one drops off, and goes along for the ride. A small pressure drop thru the un-powered one is all..
    I've heard of problems with trying to start the downstream one when it is spinning? Maybe they spin backwards sometimes.
    Also if you flow thru an unpowered ECM, like an Alpha the display lights up! Wonder if it turns into a generator?
  • Gordy
    Gordy Member Posts: 9,546
    Water turbine gen.
    To cancel out power used in the hydronic system. Even if it reclaimed something. System is circulating anyway.
  • Paul48
    Paul48 Member Posts: 4,469
    Hmmm
    There might be a government grant for that one. If you could fold enough facts in to the nonsense, they'd probably go for it.
  • NYplumber
    NYplumber Member Posts: 503
    ashp
    I wouldn't be surprised if there is a grant for ecm circulator generators before ashps....
    :NYplumber:
