To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
BANGING BOILER
The boiler bangs. Our heating contractor blames it on contamination in the water/glycol.
Can this be the cause? We have a seperator now he has recently installed a sock filter. Claims this will filter out the fine contaminants. I have a high efficiency Lochinvar Boiler. Claims the piping in the boiler is very narrow. No help as yet. Can this be the cause of the banging or could it be air in the system?
  • icesailoricesailor Member Posts: 7,265
    Head Bangers:
    What's the anti-freeze solution? It shouldn't be more than 1/3 glycol, 2/3 water. It gets too thick and the pump(s) can't push it fast enough.
    What's the boiler system pressure? If it has sediment in the boiler, it needs to be flushed out. Sediment gathered in low spots in the HX can cause your problem but I think it is more complicated that what some may think.
    Have you ever had your potable water tested? What are the results? What else can you tell us about the system?
  • heatpro02920heatpro02920 Member Posts: 991
    combustion bang or water
    What ind of banging is it? with radiant heat you should be low temp, they are normally super quiet...
    temps and pressures needed...
Sign In or Register to comment.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
