Hot water or Steam CI Rad
OhioRuss
Member Posts: 29
Is this rad hot water or two pipe steam? If steam, can it be used in a hot water system. Thank you.
rad reuse
as I do not see any upper connections in the sections, I think it is steam only.
are you contemplating a switch of your heating system from steam to hot water?
if you are choosing radiators for another system, make sure that the ones you get will be big enough to heat the room at the reduced water temperature.--NBC0 -
What I thought
Thank you for the reply. At first glance, I assumed it was hot water by having two pipes, then it looked like it was missing the upper connections as you said. I am trying to find CI Rads for a hot water retrofit. I've done the room by room heat loss calculations and I'm trying to find rads accordingly. Too bad for me, this is exactly the right EDR and it fit perfectly where it needed to.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
