pipe dope
GTD
Member Posts: 31
in Gas Heating
What is the best pipe sealant for n.g black pipe. Thanks tom
I like this stuff
Made by Gasoila
Tru Blu
I use for everything but oil lines/tanks/ect and LP, I like leak lock for LP and refrigerant {if needed}.....
Tru blu is easy to use and stays good in a lot of temps, natural gas and water... they say oil too but I havent had great luck with it and oil...0 -
inventory control
We use teflon tape, and Hercules Megalock for all threaded connections.... ........0 -
Teflon Tape &:
So do I.
I ALWAYS use Teflon tape, no matter what. And I've used a lot of MegLoc. I stopped using it not because it didn't work, but because the liquid always came out first, no matter how much or how often I stirred the can. It would get hard and I never found any product to dilute it with. Then, the brushes would break off in the can. I tried contacting them but they never responded. So, for water pipes and plastic threads I use Rectorseal #100 with Virgin Teflon. Sounds erotic. On gas or oil, I use tape and Rectorseal #5 Gasoila or Blue-Mol. If you get it on your clothes, it never comes off. I used to see a guy around that used a lot of #5. It was all over his clothes. He must have always worn the same work clothes because although they appeared clean, he was almost yellow from the #5 stuck to his shirt and pants. And if you have the cap lose and you put the can in your tool tray and it tips over, it runs all over your tools and you can't get it off. Even PVC cleaner won't take it off. That's nasty0 -
Pro dope
it is simple and works well for NG iron pipeCost is what you spend , value is what you get.
cell # 413-841-6726
Thread Sealant
Perma Bond...best product I have come across...
http://www.permabondllc.com/TDS/LH050_TDS.pdfLANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
